randy i will be emailing you shortly as i need a 69 tach dash underdash wiring harness.javed"Midlife" said:That's fairly common. I put black electrical tape on the back-side of the switch, because sometimes the rivets hit the steering column base, which is ground.
thanks randy will do that tomorrow and let you know the outcome"Midlife" said:I think you've found your problem circuitry. Remove the tach from the circuit and try again!
car has a manual trans the fuse thats blowing is on the lower rh side when your looking underdash from drivers side 20 amp, can a bad bulb on the turn signal side cause this even if my hazards work ? i will check the nss wires today,as for turn signals it seems im not getting any output from switch to turn signals even though the same wire has voltage for hazards and there is 14v on each terminal on flasher side"Midlife" said:Look for the fuse blowing or not. I'm trying to isolate what part of the circuitry is blowing the fuse. Your car has a Neutral Safety Switch wires; it is jumpered if you have a manual tranny, or goes to the automatic transmission and back again. The plug is on the engine side of the firewall near the oil/temp/coil harness, and is a four pin plug.
And just to be clear: is it the lower left horizontal fuse that is always blowing?
