SELLERSRODSHOP
on the stock harness that runs to the tranny for the neutral safety/ backup lights there are 4 wires. two are red & the other pair are black with a red stripe. i'm planning on cutting the switch off & using the harness to wire up my t5 switches. are the two red wires the neutral safety & the black/red stripe the backup switch?
also, on my alternator harness there are the two connections in the boot & there is also a single black wire. is this a ground? it was cut & not hooked up to anything, but alt. worked fine & charged, so assume its a ground. this is the only cobbled up piece of wiring on the car...
thanks!
thanks!
