Jonk67
Hi all, well I really wanted ORP's street UCA with the welded tabs but for budget had to go with the standard stock kit. I had my wheel off and noticed that my shaft nuts had turned (I marked them at install for reference). While I've got them loose for fenderwell painting I decided to drill a hole and tap for a screw (10-24). I then put the screw in and locked it with a nylok nut.
I'm just trying to keep the nut from turning, I think it just happens due to vibration/twisting which allows the nut to turn, I don't think there is a lot of force turning the nut so I hope that this small screw will stop it from turning. I don't think I could go any bigger as there isn't much of a shelf to drill through.
Will it hold? bend, snap?
Thanks, Jon
Thanks, Jon
