Its friday and my brain isn't working. My solenoid and battery are both in the trunk. There are many times I need a power source under the hood, for instance I'll be installing headlight relays and will also need power for my large fan. Since the alternator charge wire is connected to the battery post on the solenoid, that would mean its hot all the time right?? Couldn't I just attach a wire to the charge post of the alternator and run it to a small fusebox to provide power to these things?? Is there "pulsing" from the alternator that would cause problems, like for things such as a PWM fan controller? Hopefully someone here has more electrical knowledge about this stuff than I :shy
