"Dennis Harrelson" said:I'd start with the perimeter; the same seam you've already plug welded, and it's mate to the rear. then the heavier seams inside those.
"Dne'" said:Hi! here's my story! :bowdown
I found the inner shock tower bracing on Ebay, I wrote the guy and sent him some photos of the engine side of my shock towers. He responded telling me the shock towers were in need of repair. So I used my porta power and pressed the shock towers and they became flush and I welded them along the seams. Then on the outter or wheel well side, I welded in the plates that I bought from the man on Ebay. Maybe not the best way to do it, but I was still pretty new at the time. Learning as I go, or as "WE all go"~
hope this helps, and I'm sure others will chime in!
dne'
"abrahamfh" said:Okay, so both front and rear apron seam welded to the shock towers. Gotcha and Yikes.
Dne, that really helps. Wow, I think I am going to have to snoop around for those plates that go on the outside below the LCA's. That is a great idea, I am sure it not only does it help with the overall strength but also keeps all the road grime from building up in there like Fred's did.
"abrahamfh" said:Anyone have any tips on how to flatten the perimeter for welding purposes, or will just filling the gap work.
"Dne'" said:Good morning Abe! (may I call you Abe?), I was thinking about your shock towers last evening and just trying to advise you for what I know;
"Dne'" said:Abe~ I'm just ridiculously pleased that I can help now and then!!
gee, I'm amazed that there hasn't been more folks with much more experience on this adding comments! I had to go out in the garage and look closer at mine to see how it's put together~ it's been a couple years or so. I don't think I welded that part, but I did kind of smooth things over with seam sealer, urethane to make it look nicer and to keep moisture out to some degree.
Abe, is it separated/ing there where you're talking about? Maybe a finer bead with your mig? just keep it fine n simple? don't go wide with your bead? I wish I were there to look at it!
dne'
"Ponyman66" said:Abe, you're talking about the getting a bead inside the gap, but it's difficult to access because of the "rolled over" portion correct? If so, it's not as big a problem as you may think. Let your wire stick out further from the contact tip. Get it down in the gap prior to pulling the trigger for an arc. Once you start running the bead, just maintain that stick out length. One potential difficulty is you're welding a vertical surface. You'll want to weld uphill for better penetration. With the limited area you're in, you won't have a whole lot of room for tip movement side to side. Just do what you can with the area you have. Your welds show you're getting the hang of it. This is just one more thing to master! You can do it!!! :thu
"Dne'" said:
