Some of you probably saw my efforts at putting the '90 5.0 HO/AOd into my 66 stang last summer. Well, I tried to go efi at the same time then finally gave up on the efi and put the old weiand intake/edelbrock back on. I could not get the efi part to work right for some reason and just ran out of patience. In the process of installing the weiand intake, I grabbed the '90 water oulet that bolts up to the intake for the upper water hose. I also grabbed the dang long assed bolts that went with the '90 outlet...you know where this is going. Yep, I cracked one of the holes where the bolts went into. Cracked it bad too, when I got in a hurry and used an air ratchet to zip it into the hole. It bottomed out and cracked the housing part that it attaches too. So, I shoved some silicone into the hole with a short bolt and everything was okay until a few days ago it started leaking. So, I have to get another intake to go with the carb. Stuff like this just pisses me off sometimes... :beat The local shop has a professional products dual plane intake and I am wondering if any of you have tried one of these before? I am tempted to try the efi stuff again but don't feel like getting into a long drawn out episode with that mess again.
