southern_boy
Started routing wires for the EZ Wiring harness. Wish me luck.
"cmayna" said:So boy,
Are you going to wrap your harnesses? If so, consider some dry wrap tape. It's just like the typical black electrical tape but no sticky on the back. Both of my Mustangs are done this way.
I use Elliott EE201, but there are others which are as good such as Elliott's ET501 which is more readily available on fleabay and according to Elliott's specs is a slightly higher temp resistance tape.
"cmayna" said:Trunk light vs how much you use it........
Personally, I would not bother with a trunk light for you need to ask yourself, how often in the middle of the night will you need to have a light.
"Midlife" said:Why would anyone need a light at night, when there's already a bag over her head? Hmmmm?
