What cam y'all running.
Re: What cam y'all running.
Mine will be just enough to burn tires and be kinda quick between lights but still be a good cruiser.
Sent via paper airplane.
I went with the CompCams XE262 but I have AFR heads. You have to be careful with the stock heads, once you get close to or past .50 lift the studs can pull out. Aftermarket heads normally have screw in studs. The XE262 was a decently aggressive cam but still has close to stock level vacuum for my PB. I used their free program CamQuest to narrow down my cam selection and then discussed it with my builder.
It hasn't had it's first start yet so I can't tell you any impressions yet.
Jon
Have this in my 302 with 68 4-V heads with 1.84"/1.54" valves and about 10.5:1 compression . Also used the matching springs .
Very noticeable cam .
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,600-5,800
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift:...... 224 int./230 exh.
Advertised Intake Duration:..... 268
Advertised Exhaust Duration:... 280
Advertised Duration: .......268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: .....0.509 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: ....0.512 in.
Valve Lift with Factory Rocker Arm Ratio:........ 0.509 int./0.512 exh.
Lobe Separation (degrees): .....110
Computer-Controlled Compatible: No
Grind Number: FS XE268H-10
Valve Springs Required: Yes
I'm running an E303 cam, 1.7 roller rockers...pretty lumpy and old school, but from what I'm reading, has been improved upon by the Comps XE series.
