Daves69Coupe
So i worked on more of the wiring last night and what I discovered is the following:
Problem 1:
I bolted the ground for the lower dash, put the + on the battery, dome light on, pull the light switch, ignition light comes on, I turn the light switvh and dome light stays on. I test the door jamb switch and theres continuity so thats working but dome light still wont go off.
Problem 2: I turn the car in accessory but nothing happens, not sure why until I looked at the ignition switch, which is wired wrong, All the connections are sodered so Im gonna try melting that soder and pulling the connections off. Does anyone now what color 977A should be on the attached pdf.
Problem 3: Also on the attached pdf ive clouded the engine temp switch & oil temp switch, where are these located is there a seperate harness for these?
Problem 4: Theres an arrow for 904 (Violet) I dont have a violet coming from my firewall out.
Problem 1:
