'03 Mach 1 starter issue
Discussion in 'General Mustang Discussion' started by SkidMark, Oct 3, 2018.
  1. SkidMark
    SkidMark Active Member
    Pulled the TR3650 out of my '03 Mach 1, 3rd and 4th synchros shot, replaced it with a rebuilt TR3650. Starter is now grinding when you try to start it, it will start and grind for a few seconds and then stop. Had no issues before. Tried a brand new starter and same thing. Flywheel is fine, no missing/chipped teeth. Can't figure out why it is doing this when it was perfectly fine before. The block plate was missing when we tore it apart, it only had a small piece of it surrounding the starter, it now has a complete plate. This is the only difference. Flywheel was not removed. Stumped.
  2. tarafied1
    tarafied1 Well-Known Member
    how did you replace the motor plate without removing the flywheel?
  3. SkidMark
    The plate is more like a ring and is open at the top, no need to remove the flywheel.
