I'll be adding a Taurus electric fan to replace the weak Zirgo fan, so my 70A stock alternator will not likely be up to the task. My battery is mounted in the trunk, so the charge wire will be longer than one with a battery mounted in the engine bay. What is the rule of thumb for wire size for a 130A 3g alternator? Wire length will be roughly 8ft, maybe a tad longer. I currently have either 6ga or 8ga wire meant for a power feed to an stereo amplifier (fine strand wires). I'll double check on that size, but I have a hunch that even the 8ga should be fine. Let me know if you agree.
