dodgestang
So I have all new suspension on my 1967. I installed 68 suspension that I source from John (opentracker) several years ago. Upper arms, roller perches, moog lower arms, SorT adjustable strut rods, big block springs, kyb shocks 1 1/8 sway bar. I did the shelby drop while I was in there.
When I got the aligned couldn't get the car past 0 camber.
Because of this I am unhappy with my 245 45 17 fitment. They would be PERFECT if I could get -1 camber. Car has wheel well molding that I kept in place but rolled it all with my fender roller.
On dips it will sometimes reach out and grab the driver side fender at the 10 o'clock position and bend the trim I rolled up down and out.
At first I thought maybe the tech used shims but when I was in there swapping brakes I checked it out...nope no shims. I also jacked it up and confirmed the lower eccentric bolt is at max adjustment.
I should be able to get huge amounts of negative camber with this setup so I don't understand what the problem is. Is there a length difference between 67 and 68 upper arms that might be the culprit? What options do I have? Do they make an eccentric bolt with a slightly smaller 'circle' on it to get more adjustment? Can I take out my eccentric bolt and shave them down on the grinder to cheat another degree or maybe even 2 of adjustment? If so...how much material would I need to take out? Would popping out the bolt, shaving it, then reinstalling it and pushing out the lower arm a little more through the adjustment so out of whack I would need to do it all over again or can I plug and play?
