Outlawboss
It's been a few years, but I started digging back into the mustang these last few weeks and I have run into a problem that I hope to get some help with. I THOUGHT I would be ready for Knott's, but doesn't look like it.
Engine is a 289 in a 66 coupe. It's warmed up a little with an Edelbrock intake, carb and cam. I also have long-tube headers on it.
It was fine when being started cold. Once it was warmed up and shut off for a few minutes it would turn over, but very slowly. Just enough to get it started. The problem was getting worse over time. I did a little research online and determined the old starter must be going bad. It was at least 15 years old. Battery was ok, it could turn the engine as long as I needed it to.
I replaced the starter with a mini hi-torque type from NPD. I also got a new starter solenoid and mounted it next to be battery in stock location.
After installation, the starter sounded/worked great. I had to crank it for less than 20 seconds to get fuel back into the carb and the car started. I warmed up the car, shut it off...and same problem as before only worse. This morning, even when cool, the engine would barely turn over. A few rotations and then it would just click. I couldn't tell if it was the solenoid or skipping gears. Sounds like the solenoid. I tested it with a different battery known to be working and same problem.
Took the coil off the distributor to make sure it's not a timing issue, and confirmed it is not timing.
So it's not the battery
Solenoid is brand new
Starter is brand new
What else? Could it be possible that the mini starter was damaged by the initial startup and/or heat from the headers? If anything, the mini starter should be enduring less heat than the old stock one.
I'm at a loss. Anyone else had this, or able to help narrow it down?
