I converted my car from an I6 to a 5.0 a few years ago. I have the reverse rotation water pump along with a serpentine belt setup. I have a Fluidyne 5.0 swap radiator. The upper radiator hose is on the passenger side and the thermostat housing faces almost straight up. The lower radiator hose is on the driver side.
I know that stock V8 replacement hoses will not work. I have tried flexible radiator hoses made by Gates called Vulco Flex. I just really do not like how they look at all and suspected the lower hose was leaking. I would really prefer to have molded hoses.
I was hoping someone else that had converted to a 5.0 had some part numbers for hoses they used that fit well.
I did find out that the Bronco II hose Gates 21736 works great for the upper, or at least it fits nicely anyway.
The 1970 Mustang or Maverick hose Gates 20702 is shaped right and fits the radiator, but will not fit the water pump. Its too small on that end. Its 1.5, and I need it to be 1.75 inches.
I need another solution for the lower hose. Anybody?
