So i did some junk yard hopping and found a 84 truck 351W I can get for 200$, I want to build a clevor badly, so I bought some 2V cleveland heads for 50$ that need some cleaning & probably a valve job, Then last month I found a set of Austrailian Cleveland heads for 400$, I have 3 Questions
1. Should i clean up the 2V heads i have or buy the Aussie heads?
2.Should i consider boring the block .30 over and buying a 3.850 crank/Scat H beam Rods/ and making a 393 stroker?
3. If i decide to do #3^ do i have to buy Keith Black 110 pistons or can i fly cut another 302 piston
I'm not looking for a barn burner, I would be happy with 300-350hp I just want a Clevor, This motor will get alot of miles- What do you guys think i should do???
