SELLERSRODSHOP
i'm in the parts gathering/planning mode on the tr4 project & need a little advice on which direction to go with the rear brakes. the front brakes currently planned will have 10.6" rotors & 4 piston calipers with two 1.66" & two 1.33 pistons. i'm planning on narrowing a rear from an explorer & not sure if the explorer rear discs will be compatible with the front. explorer rotors are 11.22" with a single 1.81" caliper piston. the 94-04 mustang rear discs have 10.51" rotors & 1.49" caliper pistons. if they are interchangable between the housings, will the smaller mustang brakes be a better fit with the fronts or will the explorer parts be fine with a prop valve adjustment ( wasn't too shure about running the larger rotor on the rear)? anyone know if the mustang brakes will swap over to the explorer rear?
