'65-66 Used Parts Pricing Help
hivewax
some locals called for the 289 heads and the 14" wheels w/almost new BFG tires. how much you think they cost? links pix below.
here's the other stuff i want to get rid of:
- crankshaft (casting #C3AE-N) (needs remanufacturing/rebuilding)
- stock distributor w/PERTRONIX + orig points
- 4-barrel carburetor
- Ford blue air cleaner (snorkel missing)
- stock blue valve covers
- cast iron heads
- 2-row radiator (needs welding on the top)
- intake manifold
- oil pan w/oil pick-up
- fuel pump
pix at - http://www.cardomain.com/ride/2978777/2
- RH fender (damaged from tire. big lump on the top. no rust)
- 14x6" w/3.75" back spacing, GT style steel wheels, chrome trim rings
- crankshaft (casting #C3AE-N) (needs remanufacturing/rebuilding) = 20.00
- stock distributor w/PERTRONIX + orig points = 20.00
- 4-barrel carburetor = 10.00
- Ford blue air cleaner (snorkel missing) = 5.00
- stock blue valve covers = 5.00
- cast iron heads = 10.00
- 2-row radiator (needs welding on the top) = 2.00
- intake manifold = 5.00
- oil pan w/oil pick-up = 5.00
- fuel pump = 1.00
- RH fender (damaged from tire. big lump on the top. no rust) = 2.00
- 14x6" w/3.75" back spacing, GT style steel wheels, chrome trim rings = 200.00
Of course I wouldn't pay this much for any of these items, but there's bound to be someone out there who will.
I'd think you could get more out of the 4 barrel, I sold about 6 Holley four barrels on flebay for around $40 a piece if not more, they ranged from 600CFM to 850's. They all needed rebuilding.
