Jonk67
Ok I'm to the point where I'm adding accessories back to the front of the engine. Tried to mount my PS bracket and found that the AFR heads have 3/8" threaded holes and the original PS long stud is 5/16".
Is there an insert to step up from 5/16" course to 3/8" course, like a helicoil?
Or should I drill out my PS bracket to accept a 3/8" stud? I'll have to drill both ends and the steel spacer, seems like more work than a thread insert but do like the idea of a beefier 3/8" stud. The 5/16" seems awfully thin to support the majority of the wt. of the PS pump and belt tension. The alt. uses a 3/8" bolt.
Jon
Jon
