coupster
I want to go from all drums, to front discs on my 70 coupe. I now have 70 disc spindles/brackets/hoses. No backing plates. I am thinking I will need a stock 70 M/C for disc, 70 single piston calipers, 70 rotors, and proportioning valve? is this correct? What am I missing?
Are stock rotors a "2 piece" deal with a seperate hub and rotor?
I am unsure about the proportioning valve (or lack of). It's been a long time, I don't think/remember if I have the correct one.
I only have a distribution block?
I think I will need to plumb in a proportioning valve instead?
I also have a set of Kelsey Hayes 4 piston calipers on the shelf. I was told these should fit my disc brackets and can be used instead of the single piston calipers? Will these interchange or do I need different brackets? Is there any benefit to these calipers over the stock single piston calipers? (other than I already have them).
I will begin tearing into this shortly. I still need to pick up the upper and lower arms. I have new springs/insulators, roller perches, sway bar waiting to go in. I'm going to do all front suspension, disc brake conversion, and power steering refresh. Wish me luck. It will take a few weeks, but it is not a driver so no hurries.
