Well I finally made it over to this site to some familiar faces. With the thru-core electric fan straps making a hole in my new aluminum radiator core, I've decided to do something different. The radiator is a Northern 19.5x28 and the fan is the over-rated Zirgo 16" electric. I started out just looking for some decent brackets, which I found these: http://www.summitracing.com/parts/SUM-329726/
Kinda pricey, so I figured it may be best to go with the aluminum fan shrouds. Are there any concerns with restriction of flow with a 16" fan and that large of a core using a shroud? Fan area is roughly 200 sq inches and the core area is roughly 420 sq inches. I've found two different shrouds, one from summit and the other from Jegs.
http://www.summitracing.com/parts/SUM-381101/
http://www.jegs.com/i/JEGS/555/52065/10002/-1
The Summit is 1.25" thick and the Jegs is only 1/2" thick. I don't have crap for clearance with the fan bolt flush to the core, so I have a feeling the Summit one won't work without modifications. I'm not so sure the Jegs will even work, but lets assume it does. With that large of a reduction in open area and that thin of a shroud, will I run into problems? I almost feel as if I'm blocking off over half of the radiator. Let me know your thoughts
