68angrypony
Ok well after rewiring everything the car still keeps cranking as soon as you turn the key to the right. Not all the way where it feels spring loaded. but as soon as I insert the key and turn to the right. I went and got a new ignition switch and just put it in. Same result. So I am ruling out the ignition switch. I switched the S and I wires on the starter solenoid back and forth and either it does nothing or it just keeps cranking. I even tried to reverse the wiring from the starter and put the larger gauge wire on the right (closer to firewall) and the little wire on the left (close to battery) and as soon as I did that the starter solenoid sounded like it was getting just to it with the key off. Light its starting to do what it would do with the key turned. Think that is very odd. The starter solenoid is almost new. Could the non stop cranking be from the starter solenoid? What else could it possibly be? I am completely lost here. :cry
