Jonk67
Well thanks to Steve (sellersrodshop) for allowing me to borrow his hoist I was able to pull the stroker off the stand, put it on a block and mount the AOD to it and test fit the MAC longtube headers. I knew there would be some contact from pre measuring but expected the drivers to be worse than the passengers side. Drivers side head mount is held off 1/4" at the bottom of the exh. flange and the passengers is standing off 3/4" from meeting. I actually expected them to be much worse.
Drivers:
Passengers:
They both hit first where the mounting flange contacts the pan mounting surface:
Looking for options to correct this, first step will probably be to cut the welds that hold the mounting rings on and see how much space that gives me. I don't weld, what's the best tool to use to cut the welds which are spaced apart luckily - grinding wheel?
I figure I can rotate them, cut the 1" out that sits against the pan at that point if needed (once welded back on they should be strong enough with the 'C' shape welded all around as long as the missing piece is between the mounting holes?). I asked Steve about heating the tubes one at a time and bending them inward towards the head which should kick the collector outwards? but he advised that it's difficult to get the tubes to line up flat again and they may angle away from be flush again for a good exh. gasket seal.
Steve's suggestion was to cut the collectors 3/4 of the way around just after all 4 tubes come together (~4" before the mntg. flange), then bend it outward and have the opened up area welded back up effectively putting a ~10*-?* bend for example in the end moving it away from the trans.
Any other ideas/suggestions?
I really like they way these look/mount as it appears they will clear my PS w/o a drop bracket as advertised, I think they'll breathe well with my AFR165's. I figured anything short of stock logs or shorties would need cutting/fitting anyway. Not worried about cutting welding on painted headers as I painted them with VHT and had them baked to 600*, I can always touch up after weld and have them cooked again.
I think I'll also have an O2 bung welded in while I'm at it in case I go for tuning or buy my own wideband later.
First guy to tell my wife where her striped hall floor mat went gets it :beat
Suggestions welcome,
Jon
Drivers:
Passengers:
Jon
