I suggest you measure up the center lines on the four end holes and determine just what ends you are dealing with. It doesn't look like any standard Ford end I have seen. Also use a depth gauge or caliper to see how deep the bearing recess is and also the bearing. It should mount flush or deeper. Is there no inner ridge against which the seal sits? If there is how deep is it?
