Indycanard
I was fortunate to nab a "NOS" 66 Emergency switch off Ebay recently....or so I thought.
After it arrived, I plugged it in, and nothing. I then put the trusty VOM to it, and checked for function. Nothing again, I mean no conductivity in either switch position. The wear to the electrical tabs, general dirtiness, and now lack of function makes it "used" not "nos", and broken to boot :sad
I got burned on this deal (for now anyway), and will have to send it back.
Before packaging it up, I noticed the back plate (with the connection tabs) was a bit on the loose side. I was able to gently rotate the back out of the metal switch housing. I soon found out why the switch was not working. There was no copper switch plate inside. Just the actual switch lever, a spring, and a black plastic "carrier" piece that I assume would normally have the copper attached to.
I can send it back, but I thought I would ask here first if anyone may have a dead switch that they may have parts for, mainly the copper plate. I understand the black plastic carrier part is the usual part that breaks.
Thanks all,
Thanks all,
