Borgeson PS box and Pump 67-70
Discussion in 'Classifieds (Mustang)' started by Boom, May 21, 2017.
  1. Boom
    Boom Active Member
    I have the Borgeson PS conversion box and the pump for sale. I had the set-up on the car for awhile but I took it off when a line started leaking. I meant to put it back on after getting a new hose made but never did. The box and the pump with bracket as shown in the picture. I have a pair of bolts with spacers that mount it to the driver's side head. I don't know where the hoses are, if I find them I''l include them, but you can also get them from CJs, see the link below. I also don't think I have the 3 bolts that mount the box to the frame, If I find them, I'll update the ad. Just taking up room in my garage, asking $350 plus shipping or best offer.
    Here is the link to the kit:
    Here's the replacement hoses for $67:
    [​IMG] This image has been resized. Click this bar to view the full image.
    tarafied1 likes this.
  2. tarafied1
    tarafied1 Well-Known Member
    that's a pretty good deal. My dad put that set-up on his 66 and he really likes it.
  3. guruatbol
    guruatbol Always on vacation!
    Where are you? Shipping from 84757?
    Sent from my XT1030 using Tapatalk
  4. kb3
    kb3 Well-Known Member
    The link says it's good for 68-70. I assume it would work for a late 67 without the spearOmatic?
  5. tarafied1
    My dad's was for a 66 and it came with parts to cut the shaft off the gearbox and put a bearing in the bottom of the column and mount the column to the firewall and so on. So you would need stuff like that. The gearbox should be the same. You may also need the pitman arm for a 68-70 as I think the splined shaft is different size on the early 67. I didn't do the Borgenson swap but had to deal with all that on my EPAS for my 67.
  6. kb3
    I would love to put PS in my 67, but will most likely go with the EPAS unit.
  7. Boom
    Boom Active Member
  8. Starfury
    Starfury Active Member
    I believe there are some pedal issues with the 68 column conversion as well. Been a while since I've seen a pic to compare, but I think the '68 pedals have a bow in them to go around the column boot.
