Brisket!!!
O
opentrackerSteve
Guest
Cooking Brisket for St. Patrick's day.
Applied Weber's Cajun Rub Spice and that's it.
Set pit temp to 180 Deg, internal alarm to 165 deg F.
Your cooking at a pit temp of 180? And only cooking the brisket to 165?
I didn't think you could cook it at that low of a temp, is this a packer or flat?
I always cooked at around 225 or higher and found they are done when you can insert a toothpick into the flat like its going into soft butter. Usually 195+ before its done.
I kindof agree with grabber on this one. The juiciness of the brisket comes when it has reached a higher temp.
Agree with the above. Briskets and pulled porks are cooked low and slow or high. In either case the typical goal is for an IT of 195-205. Once that is met you normally wrap it in foil and wrap it in a blanket. Put it in an ice cooler for an hour plus.
I normally cook at 250-275* until IT = 195-205* Then foil, then blankets.
Here it is at an IT of 175.
I will let it rest / keep on the grill for a late lunch.....
I snook a taste and it's awesome....
