carb swimming in gas
cmanf
My holley 1450 is pumping gas out of the breather tube on the front side just pumps it right out the tube. Any ideas?
Sounds like a stuck float. Sometimes you can tap on the side of the bowl and get it to function but it would still need to be taken apart and repaired/cleaned.
Is the carb doing the breast stroke, butterfly, or is it just treading gas?
Thanks guys.
Ill take a look in it tomorrow.
I have the paxton blow through carb setup.
I smelled gas bad took the cover off and about 3" deep pool of gas had it backfired could have been pretty bad.
