I bought a new dash pad from Dashes Direct. Overall the fit seems good. On the lower passenger side there is a mounting stud which works fine however the same mounting stud is also on the drivers side which does not seem to be stock.
I had a look at the factory build guide and it only shows a mounting stud on the passenger side and there is no hole for the stud on the drivers side. There is this small bracket behind where the stud is on the drivers side.
Has anyone else come up against this? Remove the bracket and drill the dash on the drivers side?
