Dim Dash Lights
Discussion in 'Electrical Board' started by JonnybravoM3, Jan 13, 2018.
  1. JonnybravoM3
    JonnybravoM3 Member
    Hi
    I have this issue. At night, i can't see how fast I'm going! With the top down i rely on the street lights for that
    Those who did a lighting upgrade on their gauges, can you suggest sources and links? I'm in a 65 so my dials are the classic (falcon) ones.
    Thanks! JB
  2. B67FSTB
    I think you can turn the knob (clock- or counterclockwise ) of the headlight switch , to dimm the clusters lights.
  3. JonnybravoM3
    JonnybravoM3 Member
    Hi yes but even on the max setting, i can't read it at night. Not bright enough as they are.
  4. B67FSTB
    maybe its time to change the bulbs in the cluster.
    Do you see nothing at all or just a bit ?
  5. JonnybravoM3
    JonnybravoM3 Member
    Barely... yes i want to change those bulbs. Any advice? Perhaps LEDs?
  6. RapidRabbit
    RapidRabbit Well-Known Member
    I had the same problem. It turned out to be my headlight switch.
  7. Horseplay
    Swap to LED bulbs and marvel at the brightness. Seriously, the stock set-up is just not bright enough. There are endless sources for LED bulbs. Just pick your favorite and order some up. Every light in my car is LED and not only does it make reading gauges easier, it actually makes them look better. Instead of standard yellowish light LEDs can give pure white (or any hue you desire) which really makes things shine.
  8. Midlife
    Please do not put an LED lamp in an alternator indicator lamp socket; that changes the resistance and may make charging your battery in trouble.
