Disk brakes question
David67
Looking at getting new brakes for the mustang. I currently have Granada setup and I’m looking to upgrade to a wilwood or oem setup.
I do have some 68 drum spindles in the garage and I tried to get better pads for the granada brakes and it didn’t stop as well. Went through the rear brakes and put everything new and it stops better. I’ve had the chance to drive other classic mustangs with those setups and they always stopped better for me.
Power brake set up ?
The granada set up should do the job IMHO.
Can't beat Wilwood. Clean and simple. Proven. Bleeders at both ends of caliper make bleeding super simple too. Pad change is a breeze (not that you'll likely ever have to do it). I have a manual set-up and the stopping power is incredible with very little leg needed. Did I mention how good they look?!
