AzPete
Reading on several sites, they refer to the need of a '67 distribution block to convert a 66 to the 67 dual bowl m/c for a non power drum car. Is this a proportioning valve or a distribution valve. It seems if it is just a dist. block, it should not be so expensive as it would have no internal works. Sounds like there is confusion here.
I understand the need for a proportioning valve on a disc/drum car, but is it needed on a dual bowl drum/drum? Would the delivered pressure to each axle be that different comparing the jelly jar to a dual bowl?
I plan on this mod one day so just getting all the ducks in a row.....
