Fast68back
Guest
That 3/8 union where the two right front brake lines come together? I looked at the NPD and Dallas Mustang catalog. May have to make a trip to the junkyard for one fitting..
"Starfury" said:What I believe he's talking about is the double-female union fitting on the rear of the p-side inner fender, inside the engine bay. There's a line that runs to that point from the distribution block, and another line that runs from that point to the r/f brake hose. The fitting itself is a simple brass 3/16" tube inverted flare union, nothing fancy
the block we see attached to the frame rail is actually part of the rubber hose assembly?
"Starfury" said:Huh. Interesting. I thought he was talking about the union fitting on the inner fender well connecting the two hard lines of the RH brake line.
I thought the same thing as you, Dave. Apparently 65-67 uses the L shaped brackets, while 68-70 incorporates that block into the hose.
