tarafied1
No. Voltage is the force, the current is the result. Voltage is equivalent to water pressure, current equivalent to flow rate."Horseplay" said:Aren't the volt and amp guys reversed? Volt passes through and amp is the "force" (draw) used to move the volts along.
