70_Fastback
Hell Bent for Speed
The engine will be coming out shortly for an over-haul now.
When I pulled out the fuel pump, this is what I found lying in the fuel pump arm hole on the side of the T.C. cover:
The snap ring that is broken must be what failed, letting the idler gear seperate. Just my hunch...
Nice filings in there as well:
After I pulled the balancer and popped off the T.C. cover, this is what was behind:
Did some damage to the inside of the T.C. cover as well:
you can see where the idler gear was riding. The circular damage above was there previous from the P.O. having the wrong fuel pump eccentric installed and grinding on the cover.
metal filings everywhere...
