Fastener help
Discussion in 'Non Mustang General Discussion' started by Horseplay, Apr 14, 2017.
  1. Horseplay
    Nothing is ever easy. I am in need of a special type of fastener that, to date, I have been unable to find. I'm to the point I might just invest in a 3D printer and make my own!
    What I want is a double ended stud where one end is conventional threads and the other has a press fit/locking end to secure a plastic piece to the surface of another panel. Basically, I'm looking to tightly secure a shallow trim piece (<1/4" thickness) to the surface of a panel with a hidden fastener. Something like this would be perfect.
    The base piece is very thick so I cannot use something that would pass-through from the back side. Has to be done from the surface. I could machine a pocket in the primary piece into which I could thread the pin and have only the interference portion above the panel surface to mate with the trim. Problem is the only thing I have found so far like this is in the medical field and I haven't been able to find a source from which to buy for less than a million dollars.
    My other idea (born from my redneck heritage) is to just cut the head of a bolt or screw and thread it in and press the trim over the headless end. The trim is a flexible rubber like plastic so this will likely work but if anyone is familiar with a fastener made for this type of application (surface pairing of two pieces)...and there has to be one...please give me some direction. Ideal sizing would be something in the neighborhood of 1/4" max diameter with a interference shaft length above the panel surface of 3/16". I could always also screw the threaded end into the trim and use a longer press fit shaft to go into the base material. this might actually be the better way to go now that I type it...
  2. msell66
    msell66 Burning Fossil Fuels as Fast as Possible Donator
    Use liquid nails.
    Jonk67 likes this.
  3. Horseplay
    Adhesives/tapes will not suffice. Needs to be mechanical.
  4. msell66
    That was a joke numnuts.
  5. Horseplay
    Uh, yeah. Knew that just thought I would make it clear tape/glue was not an option.
  6. Horseplay
  7. Horseplay
    I think I found a winner. Hit a couple hardware stores and started digging through all the misc. parts drawers and found this.
    Overall length is just over 1/2". I'm going to cut a slot in the top of the machine screw threaded end to allow the use of a flat head screwdriver to drive the sheet metal threaded end into the substrate material and have just about 1/8" of the stud standing above the surface. A slightly undersized hole drilled in the trim piece should hold firmly against the threads when pressed down onto it.
    I think I've got this latest problem solved!
    msell66 likes this.
  8. kb3
    kb3 Well-Known Member
    glad we could be so helpful!
  9. Horseplay
    I knew you had my back, Ken.
  10. Mach1 Driver
    Mach1 Driver Active Member
    I still like the idea of a 3D printer. Home Depot of all places had one on display before Christmas
  11. 3175375
    3175375 Well-Known Member
    3D printers are awesome. I worked on a project where we needed to provide a stop to prevent ramming the radar rack into the building wall. I suggested 3D printer stops and the management was dumbfounded. The result worked perfectly but I got little credit for coming up with the innovative idea
  12. Horseplay
    3D printing was thought of as a possible solution as I'm thisclose to buying one. Just trying to finalize selection. There are a lot of manufacturers and models out there and they are certainly not all created equal. I want to make sure what I get will serve the purposes for a while. "Resolution", media types and part size limitations are the key variables I am trying to find in the right unit. I want to be able to use various plastics depending on part need while not being too restricted in final product size.
    Anyone got firsthand experience with any units? Guidance?
  13. 3175375
    I'll have to do some digging. Presently out until May 1
