red70fastback
New Member
I've got the last of 4 coats of 2K high build primer down and beginning to final block sand. Expecting that this will be the last coat of high build, what grit do I or should I stop at? How much texture will the primer sealer require for adhesion?
I've gone from 320 to 400 on about 30% of the car. Primer sealer is planned to be the PPG Chromatic DLV80 series.
Thanks, Larry
Thanks, Larry
