front leaf spring bolt size?
Fst Blk
What is the size? Is it a special piece or can I run to the hardware store and get one?
Bill
I don't remember the diameter, but I do remember not finding the correct length. Had to buy a longer bolt and cut it to size. Probably a 7/16" or 1/2"
Remember not all bolts are equal...in strength. Make sure you get correct certified bolts.
I had to go to an industrial supply house to find a Grade 8 Bolt long enough and as others had said it was 1/2" longer than the originals... it fit fine without needing to be trimmed... I believe they are 1/2"...
