Aussie67
As I've put a number of new things in the coupe over the past few months (AMP/ GPS tracker/ Alarm systems, etc), I'm thinking of mounting a new fuse box in the boot as I don't trust the original wiring. As all the new items are mounted in the boot, its the ideal place. I've run a new fused 4mm aluminium cable from battery to the boot, in readiness to install the fuse box. The box can be mounted under the window (they are quite small), so it won't be seen.
I've bought a couple of these, as I like the idea of the LED which lights when a fuse is blown. Saves time working out which is which when it has to be changed. They run blade fuses which are easy to find over here.
Anyone have any experience with this type of box?
Tony
Tony
