How To Install Late Model Mustang Seats Into a 1965-66 Mustang
TheDude
New Member
My butt cannot make up its' mind when it comes to seats. My 1965 coupe originally came with bucket seats that needed to be reupholstered. It did not take long for me to install a reupholstered bench seat up front. Now, several years later, with no actual drive time on the bench seat, I changed my mind once again during a trip to the junkyard where I found two black, leather bucket seats from a 2002 Mustang. They were transplanted into a junky 1997 Mustang and barely bolted in. For about $80 I got both seats, including the driver side power seat track assembly with three motors.
Unfortunately, this write-up does not include the installation of the power seat track assembly due to the height of the assembly. It uncomfortably put my head into the headliner, and at 5' 8", I realize that it poses a significant problem for most drivers. I will include more thoughts on this later.
Here are the seats after coming out of the junkyard. They were pretty dirty and the passenger seat had rust stains. The driver side has a good amount of cracks and wear, but I plan to fix that later.
The first step was to clean the seats several times. To clean the loose dust and dirt, I started with a light solution of dishwashing soap and water and a soft cloth (t-shirt). After going over both seats twice, I used a solution of Simple Green and water. For the tougher spots, such as the rust stains, I used a green scrub pad. I also used my brother's toothbrush to clean between the piping and stitching. I then polished the seats with a leather polisher. After doing that, I thought that I should have first used a leather conditioner (which I will do eventually).
Still hoping to use the power seat track, I began with the installation with the non-power passenger seat. The stock 2002 seat tracks would be of no use, as the brackets used to mount the seat were much too narrow.
Interestingly, the width of the mounting holes for the seat tracks were a perfect match for the early Mustang seat platform, so adapting the 1965 seat tracks to the 2002 seat was the best choice:
First, bolt the seat track to the seat frame using the front bolt hole.
Next, you will see that there are four holes in the frame, but the seat track will not reach these holes:
No problem, because you will get to add two weight saving holes per seat!
The area where you drill the hole is thick enough to tap, just like the other holes, so tap it and bolt the track in:
Since the seat track rests on the edge of the leather cover, you may have to file down the seat track as shown, in order to provide more room when bolting it down. You can also lay down some rubber material to protect the seat cover:
You may need to file down the plastic clip to allow this lever to work:
I needed to file a good bit away to allow free operation.
Moving on to the track with the release lever, you will notice that the curved handle will not clear the seat:
To remedy this, grab a small propane torch, a mini-anvil and a hammer. Cover the seat track adjuster knob with tape to protect it (from fire, what am I thinking? It was past midnight).
Heat the handle and then flatten it:
Notice the partially melted knob. I didn't think about the heated metal melting the knob. Once again, it was late...I won't make that mistake on the next seat.
Drill the rear hole (haha...that's a good one) and bolt the seat track down. Now you are ready to hook up the adjusting hardware,
Next, you need to hook the end of the return spring to something. Time for another weight saving hole:
Now you are ready to bolt the passenger seat in. Big deal, what is the driver going to use? It's not going to be a power seat this time, so get ready for a slightly different procedure:
Because of the power seat track, the seat frame is a little different on the driver side. Note that there is just one hole in the rear and a depressed area where the seat track lines up because the middle is raised.
You will need to rip your hair out trying to find simple steel spacers. I went to Home Depot (horrible hardware section), Ace Hardware (I liked their selection better but they lacked spacers), a local lumber and home hardware store (small hardware section, no spacers), an auto shop (no spacers), then, finally, I went to Lowes just to cross them off the list. Well, I was surprised at their hardware section. Much bigger than the others, and they actually had hardware that an automotive enthusiast could appreciate, and near the end of the aisle were the spacers I had envisioned all along.
However, the 1 1/2" spacers provide unnecessary height and clearance, so I will grind them down by 1/8" - 1/4."
The depressed area still has plenty of metal to drill and tap:
The release lever will need to be flattened again, since it will interfere with the seat and the power controls.
This time, working by daylight, I devised a plan on how to cool your knob while heating your shaft:
Your wife or girlfriend may want to take notes.
There will be a hole, but you won't really be able to see it once the seats are in, however, since I have some black vinyl material handy, I plan to fill in the hole and cover it with the black vinyl.
Hook up your adjusting hardware again. Now you are ready to bolt your driver seat in, stand back and admire your work:
I forgot to reinstall the plastic cover that goes on the driver side seat back adjusting lever before the photoshoot. The seats will probably come out one more time so I can clean and condition them.
Yes, I will refurbish the rusty seats tracks when I damn well please. Yes, I will replace the worn out carpet someday, but it is a case of the "while-I'm-at-its." I also need to replace the rusty toe pan. Once I do that, I will also install torque boxes, then I will install sound deadening, new carpet and then refurbish the seat tracks. So, the carpet won't quite match the, uh, seats...
My thoughts on the power motor assembly:
I want to keep the seat platforms original, so that I can switch between the 1965 buckets and bench seat, and the late model buckets. I don't plan to do it very often, but in a few years I may want to change it up.
I think the seat platform really needs to be modified for anyone to use the power seat. At 5' 8", it's still too high for me. You tall freaks who have already removed the seat platform may find it quite simple to install the power seat.
I got some 2" wide - 1/8" thick flat steel along with some 90* 2" angled steel. I was going to use the angled steel as brackets. I would have welded them to the seat tracks and then bolted them to the flat steel. A similar setup would work well with the removed seat platform.
This shot actually shows the power seat assembly upside down. I cut each piece of flat steel down to about 16." They are shown at 24" long. I will still try to figure out a way to use the power seat track, but I am happy for now.
Please, post any compliments, criticisms, suggestions and tips.
Thanks,
Justin
Yep...better write up than I have done on them on the last two cars. For me, the power rack just put the seat to high and I did not want to get into the seat risers that much. My last set did have the lumbar support which sure was nice.
TB350
Quick question for you or anyone who knows. Do you think if you mounted the bracket to the rear hole first, then redid the front hole, would that allow the seat to go further back? Thanks, kip
TheDude
New Member
Thanks so much for the compliments.
This was brought to my attention by Dodgestang:
If you cheat the bracket another 1.5 inches forward and drill a hole in the front of the seat so that the nut it literally pressed right up against the metal where it curves up....it moves the seat back and lower enough to mitigate alot of the concerns people have with the seat height and a 15 inch or larger wheel
What harm would another hole do? This is something I could play with. I kind of thought that it should have a little more movement towards the rear. The height is fine for me, although my ideal seat location feels like it would be somewhere between the few locations that Ford provided.
TB350
I think what Nick said makes sense. Be interesting to see what you come up with. Nice job. kip
crustycurmudgeon
Moving the tracks further back would move the seat further forward, not back.
Frank
Frank
I believe that is correct. The rear of the seat starts out a couple of inshes behind the bracket in the described mounting.
Also, I did not have to apply heat to the adjuster to flatten it. I just laid it on a towel and pressed down at the current bend......flattened right out.
Sluggo
Frank
Correct.
Think about it like this, the track is bolted to the floor, if you mount it in the rear hole first it would be the same as picking the seat up from the tracks, moving the seat forward to match the rear holes.
So the seat is farther forward and you lose an inch of leg room.
TheDude
New Member
***UPDATE***
Since I did not use the power seat tracks, I decided to remove the power controls from the seat bottom so I wouldn't fool anyone, however, that leaves a big hole in the seat:
My goal was to fill the hole with something that is easily removable. I had some expandable spray foam and some black vinyl handy.
First, I covered the hole and surrounding seat cover with plastic. This provided protection and would also be easy to remove from the foam once it dried.
Next, I struggled with the spray foam since it did not want to come out. I then read the can, and it stated that it is recommended for one time uses, since it will seal itself dry in two hours after the first use (Great Stuff my arse...). Next, I struggled with the can for several minutes, and successfully pierced (or broke) the top so I could release the foam.
Then, I filled the hole with foam and covered the hole with a piece of paper so that the foam took the relative shape and contour of the front of the seat bottom:
That is just the thicker, useless tan paper from an old notebook, but along with masking tape, it was strong enough to make the foam take shape.
Next, I put the cap back on the foam and taped it shut, in an attempt to seal it and hopefully use it again someday. This step would prove unsuccessful, yet fun, since the foam will find its' way out for the next few hours and form an interesting sculpture:
After the foam dries, you might be left with an ugly mess:
I should have put plastic between the paper and the foam. I had to hacksaw about 1/4" from the bottom of the foam (the very bottom. not seen here...not the part that says "bottom" and has an arrow..okay, whatever...)
It's ugly, but the vinyl will make it look nice, kind of like primer and paint over rust:
The first attempt was just wrapping the foam in vinyl and shoving it in the hole:
Looks like crap.
After playing around, I discovered that there was some extra material tucked away, but not enough to work with:
After unfolding that flap, I realized that I could tuck the vinyl under the original seat cover and anchor it at the top and sides. If you look at the left side of the above picture, you can see that the very bottoms of the seat covers are sewn to white plastic clips, which attach to the seat frame. You can use the front clip to anchor the other end of the vinyl to the seat, which secures the foam in place. The extra flap pictured above can be folded back in:
I like it because it was cheap, easy and looks decent. In a car with all black interior, no one will notice. At least there aren't any fake power controls or a big hole in my seat. I need to do something with the foam padding edge of the stock seat cover because it is quite visible. I'll probably just color it black. I also used Mequiar's Leather Conditioner spray on the seats, which really gave them a nice shine.
I am quite happy with my cheap junkyard seats.
Kats66Pny
Not bad! :thu
I'll be adding late model seats to my 66. I forget what year they were from.. 2000 I think. They have the power seat as well, but I don't have the motor and all that for it. Which is fine with me. I probably won't even bother with hooking them up. I might leave the controls there though to make people think they work. LOL
