68EFIvert
A couple weeks back I had my fan go out on me and the engine went up to 250 degrees. I replaced the fan, changed the oil and everything looked fine. That is until this weekend when I drove the car home from a show and it was spewing antifreeze all over the garage floor. I couldn't tell what it was but it looked like it was coming from the overflow tank. My first thought was I screwed the cap up so I went to the part store and they said I likely cracked a head and it was exhaust gas causing the extreme pressure.
I then decided to do a pressure test. Pumped it up to 13 lbs and let it sit. I came back out to the garage and antifreeze was all over the ground. I tracked the leak to the lower radiator hose. Evidently I forgot to tighten the clamp all the way and it was seeping out. I dodged a bullet with that one! :dance
Moral of the story, always check the easy stuff before you go to far. I rarely do that and find out to late.
