I am on try number three with installing my intake. The first time I had small leak in the front right corner. It would drip about 10 drops a minute at idle. So I pulled the intake back off and put new gaskets and resealed everything. This time I have no leaks but have a few vacuum leaks around the back of the manifold making the car a bear to start. This is how I am installing the manifold. http://www.mustangsteve.com/intake.html All mating surfaces are cleaned with red scotch brite and alcohol prior to sealing. Am I just having crappy luck or am I doing something wrong?
