"Fast68back" said:Be careful, very careful. Spring compressors are about the most dangerous things you will do with/on an old Mustang. Car on jack stands, jack under lower control arm. Slow and easy.
"70_Fastback" said:Do not put the jack stands under the control arms - locate the jack stands under the frame rails to let the suspension FULLY drop - reducing the amount that you have to compress the coil springs.
"AzPete" said:Huh? I put the stands under the rail and use a floor jack to raise the lower arm to the point it does not lift the car but gives max compression. Then install the compressor, tighten it a bit, drop the lower arm down and the spring may be ready to remove. A lot less compression work. Making me think here....that is bad for a retired bum....
"Kats66Pny" said:Thanks guys! Oh we're putting on grab a trak 620# with 1" drop. This kit also came with new perches and a sway bar.
"Sluggo" said:Good news is you can probably get the new ones in without compressing them.
I like Boobs!! :10"Kats66Pny" said:Aren't most men intimated by boobs? :craz
"Kats66Pny" said:Ok this compressor is really annoying. Can't seem to figure out how to make it work (even following directions that came with it).
If you put it down in the springs, the bottom of the spring lifts off the perch, but the threaded bar of the compressor presses down on the perch and neither spring nor compressor will budge. Another thing, is the top part of the compressor (red arrows) suppose to be so loose and just be able to slide up and down so easily?
this is the compressor I have. Rented it.
