Leaky Steering Hydrolic
Discussion in 'Engine and Drivetrain/Mechanical' started by JonnybravoM3, Mar 25, 2018.
  1. JonnybravoM3
    JonnybravoM3 Member
    So car is up on the lift to see where this leak is coming from, as always!
    Seems to be from the cylinder Rack and piping. Waiting for Tech to tell me exactly what parts I need to order, but can any experts identify these?
    Thanks all for your continued support!
    JB[​IMG][​IMG][​IMG][​IMG]
  2. JonnybravoM3
    JonnybravoM3 Member
    Steering valve and steering pump leaking [​IMG][​IMG][​IMG]
  3. Horseplay
    Horseplay Well-Known Member
    Pretty normal for all those to leak at some point. The big parts are rebuildable or replacements available. Hoses should just be replaced.
  4. 3175375
    3175375 Well-Known Member
    The power steering system on these Mustangs sucks, which is why I ripped mine out. I got sick and tired of replacing components every 3 years or so, so I ordered a manual center link and ripped all of that stuff out. It appears you need a new RAM and hoses.
  5. JonnybravoM3
    JonnybravoM3 Member
    Yep my Summit shopping cart as of 2 days ago the fun never stops ![​IMG]
  6. 3175375
    Good luck
    JonnybravoM3 likes this.
  7. crustycurmudgeon
    crustycurmudgeon Well-Known Member
    If that's your pump on the right, that's not an Eaton pump, which appears to be what you ordered.
  8. JonnybravoM3
    JonnybravoM3 Member
    I don't need to have the same pump, I just need a pump that works and doesn't leak
  9. crustycurmudgeon
    [​IMG]
    The Eaton pump, pictured above, requires a different reservoir from what you have. It uses a top mount reservoir, whereas your reservoir encloses the pump.
  10. JonnybravoM3
    JonnybravoM3 Member
  11. crustycurmudgeon
  12. crustycurmudgeon
    Perhaps you could find someone in the US who has a junk core to return to Summit so you can get your $40 core charge back.
  13. JonnybravoM3
    JonnybravoM3 Member
    You were right. Just chatted with Summit. This will not work with my set up. Well, I'm out 75 bucks... lucky everything else I've ordered will work and they sent me the link with the pump that would work... which is this one
    https://www.summitracing.com/int/parts/ado-36p1221/overview/
  14. JonnybravoM3
    JonnybravoM3 Member
    BTW thanks for pointing that out... much appreciated... guess I thought I could just take the old system out and replace it. I guessed wrong!
  15. JonnybravoM3
    JonnybravoM3 Member
    OK now I'm stressing a little, im unable to find this pump anywhere! Even on Summit it's on back order until May or longer!
  16. crustycurmudgeon
    Can you have yours rebuilt? If it was working and full and you weren't hearing any groaning noises, you probably just need to reseal the reservoir. I don't know what else might be involved, I'm sure you can find out online.
  17. JonnybravoM3
    JonnybravoM3 Member
    OK so I've found some online.
    My issue is, my car came without AC, so the one installed looks similar to the models without AC.
    I installed aftermarket AC (vintage air)... So the replacement pump would still be the one without AC? Or would I change it to one with AC? The pump itself, the filler neck is at an angle for the ones with AC and straight for the ones without AC.
    Thing is even with my AC system my current filler neck is not interfering with anything.
    Attached more pictures of mine[​IMG][​IMG][​IMG]
  18. crustycurmudgeon
    You can use either one, since the straight one doesn't interfere with your aftermarket AC. I don't know why Ford didn't just use the angled filler neck version on all cars.
  19. JonnybravoM3
    JonnybravoM3 Member
    Thanks!
    I ordered the BBB one now. I found a few others, are they pretty much the same? I can't tell! Double the price tho.
    [​IMG][​IMG]
