Fast68back
Guest
'73 Mach 1 Mustang
This car has been 95% restored but has been sitting for 1 1/2 years. It does get started every once and a while. It has 2500 miles on rebuild. Please read whole ad cause I will list both good and bad. Two years ago this car would have sold for $XXk plus. We are selling it cause we have new/lost interest and need the space. Have plenty of pics cannot post them all here. Asking $ . Serious inquiries only. No Trades/Cash only/NO TRADES
New suspension and steering
Heavy springs front & back (non-factory)
Radials (BFG), 15" Magnums-7"front/8" rear- McGuard locks
Racing shackles/poly
Gas Shocks
Rebuilt front-end
Optional steering g-box-poly cookie (box is from a Boss 351)
1" front sway bar/poly end links/bushings
3/4" Rear sway bar/poly
New power steering booster and hoses
Dual exhaust but stock headers/ FlowMaster mufflers
Rebuilt brakes-front & back, semi-met. front discs, new rotors, braided steel front line
Adjustable proportioning valve
High volume oil pump/moly shaft
Edelbrock performer manifold, 351 Cleveland engine
Rebuilt engine /cast aluminum valve covers hex cover bolts/ARP bolts/Summit chrome breather
Holley 600 cfm Carb with 3" chrome air filter (Summit Logo) electric choke
New radiator
Rebuilt FMX automatic transmission/B & M shift kit
Rebuilt 9" rear, 3.50-1 (open) 28 spline
New blower fan motor/heater core/box gaskets & foam w/new heater connection valve
New seat upholstery front and back
Grant steering wheel/turn signal lever & turn signal cam repair/new horn kit
ignition switch/cyl.
headlight switch
Dash pad
Dome light & lens
Gear selector bushings/bezel/seal
Mach style grill and flip open gas cap (both original)
New rear-view mirror, window handles, sun-visors, drivers-side arm rest, windshield wipers
New door panels, Halogen headlights, water pump, radiator hoses
New alternator, starter solenoid, voltage regulator, starter, battery and cables
All metal in interior has been painted, same with plastic, new carpet
The Bad:
Has a few cancer spots showing up on the upper wheel wells, has a few knicks and scratches.
Lower front spoiler has slight damage, Rear spoiler brackets broken but spoiler still in good condition, headliner was replaced but now damaged, needs tune-up, key will not push divers side lock up all the way, dusty and dirty but we will work on cleaning it up for you in the next few days.
Gas Shocks
Rebuilt front-end
New radiator
headlight switch
Dash pad
Dome light & lens
The Bad:
