DEL65
Of The Morons
I'm having trouble with the alignment of the z bar, clutch fork, and upper/lower rods. T5 bell and fork installed and I suspect the problem is caused because the new clutch fork is probably shorter than the original T10 fork. I attached a diagram below.
The misalignment is exaggerated, but accurate. Currently, the upper rod to the pedal is bending toward the block and rubbing the side of the firewall hole and the lower clutch rod is putting pressure on the cotter pin. It looks like the upper and lower rods need to move outward from the z bar in order to be parallel. I do not know if my z bar is bent and need to check the clutch pedal bracket (but it is probably OK)
Also, the z bar is not completely horizontally level. It is a little lower at the block and higher at the frame rail. I am using the teflon bushings and was not planning to install roller bearings.
There are some fixes I'm looking at, but could use some ideas.
1) Opentracker's Clutch Rod Kit. It looks like it may move the alignment points outward.
http://www.opentrackerracingproducts.com/clutchrods
2) Put washers on the block side of the z bar to ove it toward the frame rail to align the upper rod. Then modify/weld a tab onto the lower part of the zbar to align the lower rod.
3) Anything else?
3) Anything else?
