bravenrace
Okay, now I understand about the 28oz and 50oz imbalance (I think), and I fully understand internal engine balance, but I'm having a problem that has led me to question some things.
I converted from an automatic to a T-5 this past winter. My '65 currently has the original 289 in it, so I bought a 28oz flywheel. I made no changes to the engine at all.
Now I have a vibration that increases with RPM, regardless as to whether or not the clutch is engaged. All the conversion parts are brand new, with the exception of the T-5
bellhousing.
Here's the thing. If the flywheel has a 28oz imbalance, why doesn't it have a dowel pin or some other means of indexing it? Installing it in any position would seem to be similar to putting a wheel weight in the wrong place. Or should it be indexed? I think I'm missing something when it comes to understanding the way the SBF is balanced, and every source I can find talks only about the differences between the 28 and 50oz engines instead of explaining the theory of how the engine is balanced. Can anyone shed any light on this for me?
Thanks,
Jim
bellhousing.
Thanks,
Jim
