tarafied1
Dave,
Now that I switched to the FPA headers I have room for the power steering. I have accumulated the parts (except they are all used) to put Power Steering on my car. I should rebuild the cylinder and valve and replace the hoses. I may need a bracket for the cyl. to clear the headers also. OR... I could just swap the non-power steering gearbox off the POS coupe you gave me. Right now I have a PS gearbox without the PS and it's a real bear to park and steer in a tight location. In June as you know I plan to do the Hot Rod Power Tour. I'm worried if I go thru and rebuild all this stuff and install it that I may have some issue during the tour (leaks, something breaks, you know). If I just switch to the non PS gearbox it will be a lot easier to steer and less stuff to worry about but I don't know if the gear box is sloppy and I lose the quicker ratio. What would you do?
