seize ?
Discussion in 'Engine and Drivetrain/Mechanical' started by B67FSTB, May 30, 2018.
  1. B67FSTB
    I want a 6 AN fiiting to fuel pump but don't know the seize.
    It looks like a CARTER fuel pump.
    npt ?
    3/8 ?
    1/4 ?
    I know its a reverseble flare but what seize/thread ?
    see pic
  2. Horseplay
    Almost always 1/4" npt. Judging by the nipple on the pump I am pretty sure that's the case here. 3/8" npt is huge for a fuel line. Like, feed a drag motor huge.
  3. c6fastback
    c6fastback Member
    Probably 5/16 inverted flare
  4. Horseplay
    The fuel line itself would be 5/16" but aren't the threads in the pump 1/4" npt?
  5. B67FSTB
    was thinking the same here...
  6. Mach1 Driver
    Mach1 Driver Active Member
    I naturally assumed #2 below. You meant size ;)
    seize
    sēz/
    verb
    1. take hold of suddenly and forcibly.
      "she jumped up and seized his arm"
      synonyms: grab, grasp, snatch, take hold of, get one's hands on; More.
    2. (of a machine with moving parts or a moving part in a machine) become stuck or jammed.
      "the engine seized up after only three weeks"
  7. B67FSTB
    Size , yep thats what I mean. Sorry ,didn't take the time to look up if it was spelled right.( bad english, my bad ) :confused::confused:
  8. tarafied1
    tarafied1 Well-Known Member
    You got parts! They arrived today
  9. B67FSTB
    Thx Craig .
    tarafied1 likes this.
