34isgreat
A few questions...
whets new
carb (rebuilt)
plugs
plug wires
coil
distributor cap
rotor button
points
condenser
fuel pump
Problems I have...
1. From a dead stop when first driving off the engine hesitates. If you baby the gas pedal you can prevent it from stalling out or if you gas it from the dead stop you can avoid the stall also. Does this when in park or natural.
2. Also when driving at a constant speed the engine rpm has a VERY slight what I will call a flutter. At first I thought the transmission was slipping but the engine will do this when the car is in park also. Does not do this when the rpm is increasing or decreasing.
And a question
Can came with saddle int, I see I can order saddle carpet but my car has black carpet and a black dash pad, which is correct? I do not think my carpet has ever been replaced.
whets new
carb (rebuilt)
plugs
plug wires
coil
distributor cap
rotor button
points
condenser
fuel pump
Problems I have...
And a question
