AzPete
..in a 64.5 Vert. Went to start the car after getting everything back together and the starter stayed engaged. Key turns but does not shut off car. Pulling battery cable to shut off. Once the starter is engaged, it does not disengage until the battery cable is pulled. Replaced starter solenoid, no change. Ign. switch seemed to test good.
At what point does the starter solenoid disengage the starter from the motor? I am drawing a blank on this for some reason.....
This came about out of the blue. Been working great up until now....
